By p5200
20240217_114429.mp4 -
By Uglyside38
By Werewolf
By Gwbarm
I got my no spark issue sorted out, got it running on the old aftermarket carb, but it didn't want to take throttle even after cleaned it, didnt really want to waste time on it, so I order a new one which is on its way, so not much to post here, but I wanted to start a new thread. I am stating to clean up the plastics thought I might as well do that while they are off, they were a mess tree sap, bird dropping, mold and what ever. Washed them good and got all off so I could see the oxidation , decided to wetsand with 600 grit waterproof sandpaper, and used Armour All instead of water. I figured it could put some of the moisture back in that was lost from sun exposure.
Working fairly well I will keep going finer on the grit and see if it will polish
By Gwbarm
Similar Tagged Forum Content
- 1 reply
- 5,106 views
- 16 replies
- 4,658 views
- 4 replies
- 7,871 views
- 2 replies
- 5,070 views
- 0 replies
- 4,170 views
