By vaneleus
By Olchap
Hi, I am new to this forum I am currently working on my 1989 Yamaha front end. The cv axles were bad so I changed them on both sides with all new wheel bearings. Now I'm looking at the front brakes and the 2 cylinders for the brake shoes on both sides do not work at all. I am also new at working on brakes so its a mystery to me what needs to be done to fix the cylinders. Can somebody please help me with these brake issues? See the image below.
Thank you,
Olchap
By RussB
Has anyone found a rebuild kit or an aftermarket replacement for the original which costs 500.00 US dollars?
By Matdum
Is there a common trouble to have the connecting rod bearing failure on a 2006 330 polaris magnum ? I have one who have failed and i want to know if there is something to check specifically
thanks a lot !
By Rickm59
I have a 2022 Kymco MXU150 and have been trying to bleed the rear brakes for several days. I have used a vacuum and also tried the lever pumping. i took the caliper off and compressed the piston with a C clamp and had a tight brake lever. I put it back together and still cannot build any pressure in the brake system. Any ideas from anyone? Thank you
