King Quad 500 Anniversary Edition
Underdog
Im going to look at a 2013 king quad 500 axi this morning that I saw advertised by a local dealer. After I got more info from them it turns out to be an anniversary edition. What is the differences between this and the regular axi? The price of the bike is $7900 and I am just wondering if its a decent deal. Also it has a different paint called metallic matte red? Anyone give me more info on this model?
Took it out today for a quick spin and a little break in time. The king Quad is fantastic in every aspect and will serve my riding purposes well. The only thing it needs is a better set of tires, Can anyone help me out with some tire suggestions? I do mostly trails and some aggressive hill climbs with minimal mud. Going riding tomorrow morning and see how she does on the trails.
    • By Spritee1
      not sure where to look next
    • By NZrider
    • By jatho
    • By mkibbe
