2006 Kawasaki Brute 750 - Spark Issue
google7
ok so I got this 06 Brute force 750 in the shop came in no start put a new battery in turn key on and 30A fuse pops replace it try again another 30A fuse gone check wiring harness found 4 prong plug brown and black/yellow wires rubbed through and shorting out fixed that issue replace fuse and try again..... 30A fuse pops again play around for a while and found the CDI has shorted out on the 4 prong plug in cdi side . there was a dynatek cdi box in gave customer choice stock cdi for 300 ish or dynatek for 150 ish brought in new dynatek plug in and starts nice iddles for 5 to 10 seconds and dies ... crank it for a bit nothing ... turn key off then turn on and start .. starts up idles for same amount of time then stalls check out and no spark
why would it start and stall after 5 seconds and have no spark
I'm confused
please help
I'm confused
please help
Ignition switch itself could be faulty, ign switch is a good place for power and ground to meet (blown fuse) wich is killing the power to the cdi, or the cdi is detecting <> 5volts dc and shutting down. Ck your roll over sensor as well.
  • 4 years later...
    • By ethie
      Hi All
      not sure where to start
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
    • By DrtyGrlKristin
