I was just given a 1996 wolverine for Christmas from my father in law, needs a new carb. The cheapest that I can find a new one is $500, looks like it's an oddball carb. Is it possible to use a warrior carb which is a lot less expensive and more available? I found an aftermarket wolverine carb for like $170, anyone had any luck with these?
Thanks!
My father in law took it to a dealer to have it rebuilt but they told him that they couldn't get the main jet out of the nozzle. So someone clamped onto the stem that the nozzle goes into with vise grips attempting to hold the nozzle still I guess, now the whole stem will turn in the base of the carb, looks like it's screwed to me. Thanks for your reply!
ON the Hondas and Yamaha most of the time i had to drill out the 14mm nut that hold the enrichner cable to the carb. bore out the inside so cable would go down in there far enough to give plunger enough free length to close. Dont assume jets are correct size, dont expect them to have numbers on them. I try and order fact name brand jets and put those in place of the ones that come in it.. You will get your best results that way. If you happen to need any used part for your Kodiak i may have it. Fresh part out!
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By cruteg8
    • By Rick Shropshire
    • By Need-help-with-quads
    • By Freddie
      My first quad and I have a problem. I have a Kawasaki Bayou 300 1997. When I start it. It will go on high idle for about ten seconds before it goes down to low idle. It does this even when I don't touch the throttle or the choke.
      Also, when I give it some throttle and let go. It will come back to fast idle for about ten seconds before it comes down to slow idle. Therefore I have to wait for it to slow up before I can shift. The throttle linkage drops right back to the stop on the carb buy the rpms stay up for a while. If you have any ideas what might be wrong please let me know. thank you Fred
