2008 Yamaha BB - Issues After Rebuild
orangeman100
Just rebuilt the top end on my 08 big bear 400. Piston rings wristpin gaskets. Got it back together it runs no back firing or popping but it takes a lil long to idle down and every now and then it kinda burps or misses for a split second and not often either I guess and then recovers just fine. Could the timing be off a tooth and cause this or would it be backfiring and popping a lot? Any other ideas?
    • By N00bie
    • By ResQ91
      Hi Guys!
      Or ??
      Dave
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
    • By Drillbit
      Hey all,
      Thanks!
    • By HSTAR
