Similar Topics
By 406offroad
I have a 2014 CForce 500 and the pull start is not cooperating. It seems as if it is not releasing the compression thus allowing me to spin the engine with the pull start. Any ideas?
By subetha73
Up until the other day, I could electric start in any gear, now it will only start in neutral.
Thanks for any help:)
By BruceG
I have a Timberwolf 250 that will only shift into reverse when it is in gear. It will not shift if in neutral. Has anyone had the same issue and if so how did you fix it?
By thegipper
Have replaced, Carb, fuel pump, CDI, plug, coil,fuel filter. Will crank but not srt. Getting spark and battery is fully charged 12.6V
Any suggestions????
By Sussy0909
Alright guys I'm starting to lose my mind working on this bike I have spark, fuel, compression, and timing lines up. But it still won't start. So far this is what I've done
Checked camshaft timing
Loosened valves are super loose
Wet cylinder test.
Cleaned all electrical connections.
Removed exhaust ( thought maybe it was clogged)
The bike Bike has a fresh battery in it when I first got the bike the cables were hooked up the wrong way. I checked the 2 20amp fuses under the seat and there in tack. But none of the lights and push start work ( I've been jumping the solenoid)
Also when I first got the bike it had a really weak spark barely anything after cleaning all the connections I managed to get a bright blue spark ( like in the video)
The only thing I can think of is the bike is not in neutral. The rear brakes are stuck and it has 2 flat tires so trying to shift into a different gear is impossible. It gets spark though so I don't think it has a neutral safety switch.
Here's a video of my compression readings and spark. Any advice would be greatly appreciated
The bike has 120psi of compression. I did a DIY leak-down test. Most air came out of the oil dipstick which indicates bad piston rings. The bike only has 1400 miles on it, And still, with 120psi of compression I should at least get a stutter or a few pops like it's trying to start
Thanks for reading any advice would be greatly appreciated.
Similar Tagged Content
- 0 replies
- 1,400 views
- 0 comments
- 1,500 views
- 2 comments
- 2,532 views
- 21 replies
- 10,698 views
- 0 replies
- 1,805 views
Gallery Images
3
8By iball511,
7
4
3By mannyortiz7,
1
3
3By dirtqueen,
6
1
4By mannyortiz7,
5By jpjones789,
3By Ai-noval,
7
1
0
2
3By Brand22b,
3
1
