By McG75
Sorry I suck at these forums so if you see this submitted under update status, my bad. Anyhow this is a new shock for a 96 Yamaha Kodiak 400 4x4 it fits my 96 Yamaha Timberwolf 250 4x4 perfectly. Little narrower are the bottom than the original but everything else is perfect. I extended it to almost a half in from full extension because I’m pushing 350 pounds. It rides and hold me well. So if any of y'allRace driven shock. have been looking for one and didn’t want to do the research here it is.
By p5200
By onequad
i got a 93 400 Kodiak the frame on one side is rusted out. is this a comin thing? was wondering if it worth the tumble to put in a used one. I'm worried most of the bolts will brake. it don't look the rusted over all. just the part were the frame boke in half. do all kodiaks have the same frame
By Johnnyhorsepower
I finally found an awsome app for your phone that shows you on a map all the trails near your location. You can read or add reviews, look at picts...etc
Its called: atv escape
John
By Hagbard
1990 Suzuki LT160e that has been frame-off restored and motor swapped with a LT230e. Motor has new Wiseco piston, Shindy valves, upgraded valve springs. New carb. Full DG RCM Alloy exhaust and oversized header pipe. All new tires, rears are Maxxis RZR Plus MX, new seat cover, all new plastics, new bearings and seals all around, fresh brakes and new tie rods.
Took me a year to finally have that light bulb epiphany oh sh** moment when I realized one crucial mistake from last fall, corrected it, and it fired up and ran like a champ.
