Hello to all!
New member
I have a 1984 Honda Big Red 200ES that has no spark. I was out riding it and it just quit. I replaced the coil and CDI but that was not the problem. I borrowed a Honda service manual and went through the ignition system section and checked for possible problems. One check was for the alternator exciter coil. On the black with red tracer wire it said there should be 100-400 ohms between the wire and ground. I had zero. If I tested this right that might be the problem. They did not show how to test the pulse generator. I would like to get some feed back before I throw more parts at it.
Thank you for your time.
    • By flyinbrian365
      What's Covered:
    • By flyinbrian365
      What's Covered:
    • By quadnut20
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
