I have a 2002 cannondale cannibal 440 with the 450 kit. Recently I was riding it and it seemed to backfire out of the airbox then stalled? I started it back up got it back to the house, noticed my airbox boot had a tear in it and some of it was sitting on the throttle body. Now my cannibal wont turn over, what could be wrong with it? could rubber that fell into the throttle body be removed ? thanks
Yes I just check the valves and one is bent. Do you know where I could get valves and shims for the buckets at? or if they are universal with any other quad? Thanks
    • By quadnut20
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By mikeexplorer
    • By Kurt Reiser
      My quad will not run with the airbox hooked up  Will not go past quarter throttle as soon as you unhook the tube at the back of the carburetor it runs great  does anybody have any ideas what it could be I have a bad fuel pump one on the way can that cause the quad to run like that
