Development of ATVs
ATVs (all-terrain vehicles) were first developed during the 1950s. The earliest models had six wheels instead of the four that riders are now familiar with. Honda was the first company to make the 3-wheel ATV in 1970. These were famously displayed in the James Bond film, 'Diamonds Are Forever.' Originally called the US90, the ATV was purely for fun, made with very large balloon tires instead of the mechanical suspension and smaller tires eventually introduced in the early 1980s. One of the most important versions of the ATV was the 1982 Honda ATC200E Big Red. Read Full Article
Development of ATVs | ATV Reviews
Create an account
Register a new account
Sign in
Sign In Now
    • By Ejwill
    • By oxidized_black
    • By Ejwill
    • By Chucksta
      So.. It has now become cranky about changing from "drive" to "reverse". Sometimes it's seamless as it's always been, other times it just goes "click, click....click, click " when going from reverse to forward, or from forward to reverse..  Then it gives up and just stops at neutral.  Only thing that seems to help is to give it a bit of a bump / wiggle with my own weight. Any ideas as to what to check? It's low miules / hours .. Dealership maintained..
