It looks pretty cool but it also looks like it wouldn't be the best atv it doesn't have much ground clearance and it is very big. Also I don't know if it would handle on the water as good as a straight up ski. It would be convenient, but did you also see the expected price. Whoa!!!
  • 3 months later...
    • By BillR94
    • By HHurks
      Hi to all
      Just thought I would start a poll on this topic manly because I'm not a fan of belt drives. Just want to know which you prefer.
    • By mikeexplorer
