I have a 93 LT-F4WDX and the clutch is slipping and not engaging. so far if i let it warm up for a while it will go, but not anywhere fast and even the slightest water will disengage the clutch. I have been limping it along by putting thicker oil in it, but now I wanna know how to actually fix it. Do you have any ideas on what parts I need? what is broken and how do I fix it?
THANK YOU!
    • By logray
      Hi all,
    • By HoldenBoy
      Hi all,
    • By quadnut20
      Just picked up a 2025 Yamaha Kodiak 700 fixing to do a EPI Clutch mod to it since I dropped bigger tires on it !! Air box , exhaust , and programmer next !
    • By sunn
      The clutch engagement on my 2021 cforce 400s was approx 2700 RPM, very abrupt/not smooth.   I obtained a "kit" from RNG consisting of a blue painted spring (spring force unknown) with 12 gram weights, as measured on my postal scale.  Installation was easy; 18 mm and 30 mm (not 32 mm as seen on other writings) impact sockets for clutch housing removal.  The resultant clutch engagement was still up to approx 2500 and very abupt/not smooth.
       The original spring was labeled p/n 0951-1021 (specs for spring force 300/1600) with 18 gram weights.
      I called RNG who told me the kit should work fine for my ATV, but that wasn't the case as I found.
      The RNG spring was slightly longer than the stock spring, but felt slightly easier at initial downward force but had more resistance than stock as I continued to push down.  RNG would not tell me what the spring force was.
      I then tested the clutch with the RNG spring and the OEM 18 gram weights with the resultant engagement RPM of about 2050 RPM, a little smoother engagement but still not good.
      I am really struggling to get any answers on the best combination of spring / weights to achieve a smooth engagement of maybe 1800 RPM.  Note; idle RPM is approx. 1600.
      I have searched all the forums and cannot find good information, and RNG appears to be not willing to share information.  What gives here?  Anyone with experience to share?
