I've taken the rocker cover off the motor I see that the timing chain goes all the way down to the crank how can I take the top end up with the chain well I need special tools and what with the torques specs be. I appreciate any input I can get
Unbolt the sprocket from the came shaft then drop it down to remove the chain. Be sure to keep tension on the chain so it doesnt slip off the drive sprocket in the crank case. Engine needs to be TDC. However, before you do this work, I suggest you get a manual.
    • By cruteg8
    • By Yamahahahaha
    • By DexKing
      Good day everyone!
      I am pretty new to ATV/UTV/Small engine repairs and would like input on your absolute must-have specialty tools for maintenance and repairs. Aside from the obvious wrenches and sockets, what are some more specialty type tools you use for troubleshooting? I don't plan to open a repair shop or anything, I just do this as a hobby. Looking forward to your responses!
    • By cruteg8
    • By sunn
      Any ideas?
