My quad will no longer start using the electric starter. When you push the starter button, you can hear the starter relay (adjacent to the battery) click but the starter is silent. Bad starter relay or something else? Help!:confused:
Try using a known good battery to start it or jump try to jump start it with a good known batter. If it starts, your battery is probably bad. You can also try to start it by taking an old screwdriver and jumping the two large terminals on the solenoid. If it starts your solenoid is bad. Also try taping on the starter with a hammer while performing both of these tests. This can help you find out if the starter is going bad. Sometimes the tapping can get it to spin if it has a bad spot on the armature.
    • By Rockbottom
      What should i test next?
      thanks ahead
    • By Mister907
    • By LMI
    • By HoldenBoy
      Hi all,
