Well today i was working and seeing if i could get my suzuki 160 running. I took the plug out to clean it or see if it needed cleaned. It was covered in oil. Black thick oil. If i heated it up i might of been able to get a drip off of it...(it is like 35 degrees right now). It also clanks when i crank it. The clank is always in the same spot. It never it in a different place. It will turn over but work fire up and idler. It was idling but now it wont. Could i have bad rings or compression. Maybe a head gasket. The top end has a layer of oily filth on it.
Is having to retighten the chain every few rides normal either? It seems like the chain is always lose.
Oily plug is usually not a big deal especially since you starting and stopping it often. Check it again after you get it running. Should burn off. It does sound like you have a bit of an oil leak. Again, might not be a big deal. When was the last time you checked the valve adjustment?
Drive chain might be stretched. Will come loose as it heats up. If you cant afford a new one, just keep tightening it.
    • By jay41198
    • By LMI
    • By kevinohio
    • By buriedpast
