GOODY37
99 kawasaki prairie 300 four wheeler ignition question
I have a 99 kawasaki prairie 300 4 wheeler that was stolen from me, and i recently got it back. It had been hot wired, and ignition busted out. I need to know what are the color of the wires that connect to the ignition switch? Thanks in advance.
Share this post
Link to post
Hi. At least you got it back!
It's not a model that I'm familiar with but midwestmanuals.com has a downloadable pdf that seems to have a vast amount of info on Kawasaki quads. This includes wiring diagrams for everything since time began. [Maybe I exaggerate a little bit there.]
The wiring on these things seems quite simple. Good luck.
Share this post
Link to post
  • Similar Topics
    • By Steve Howard
      Ran find shut down the quad next day would start and idle when you try to accelerate it would start popping through the carb got a rebuild kit soaked it in chem clean after break down for 12 hours on slow vibrate reassembled and adjusted per manual still the same thing any help would be really appreciated thanks and happy ridding
    • By Andrew Baker
      I need help with wiring on a 1998 (I think, 10th digit of the VIN was W) Bayou. I'm not getting spark, I'm pretty sure it is due to grounds being off because the harness is pretty hacked as far as the electric start and charging system goes. I'm needing a good wiring schematic. I found one online and there are a few things that don't add up on it so I'm skeptical that it is really for my year and model. Any help would be appreciated. Thanks.
    • By bodon
      I have a 2011 850 Sportsman.  Has been absolutely trouble free except for 1 thing. I am on my 4th. ignition switch. I don't know if it's that they are all chinese junk or what.  It gets to a point  when you turn the key and it will act like the battery is going bad. Cranks real slow or not at all. Put a new switch in and its fine. New one will last 1 1/2 - 2 years and its junk. I've had the Polaris brand and after market. As a matter of fact the original one lasted the lest amount of time.  Other than that it's been a perfect machine . No electrical problems. No battery problems. Just curious if anyone else has had the same issue.
    • By Sonders
      It appears that the Service Manual thread at top of forum is dead as all the links no longer work.  I'm actually looking for service manual for a 2000 KVF300 Prairie that I just picked up.  Does anybody have link to one that they can share, or know where I can find one?  Thanks in advance for any help.
    • By Jay Reddick
      Hey guys, need some help with my 2016 Yamaha Kodiak 700 4x4.  Was riding and it started smoking below the air box and then Caught fire.  We got the fire put out quickly with a fire extinguisher.  Many of the wires below the air box got damaged.   I purchased a new wiring harness for the atv and replaced that as well as any other damaged cables or parts that burned up where the fire was.  I also replaced the regulator, the ECU, and the starter solenoid. I also replaced the stater since some of the cables that went to the regulator were damaged.  It acts like it will crank but it won’t turn over.   The fuel pump initialized when I turn the key so it’s working.  I’ve spend $1500 on parts and no luck yet.  Any suggestions?
  • Similar Tagged Content
    • By Guythis448
      Looking for help on wiring up stock wiring harness specifically for a '88 Honda TRX 300
      If anyone could drop a link or send me a PM it would be much appreciated
    • By Ashton Crawford
      Hello everyone, i have 2000 Polaris Trail Blazer 300 I’ve been stumped on for weeks. I’m having a lot of issues starting the quad. I cleaned the carb spotless because I thought it was a carb issue and bought a new fuel line because it wasn’t getting fuel. The carb gets fuel perfectly fine now but it won’t start. The spark plug I a little worn out but it’s good enough for just one start. The only time it does “start” is when I spray starter fluid into the carb. But it never stays on. It’ll start for a bout a second then just die out immediately even if you’re giving it some throttle and the choke is on. I have no clue what I should do. If you need more information, have questions, or have any slight idea what the issue would be and how I could resolve it. Please reply ASAP. Thank you.
    • By Alan Callison
      OK ya'll.My son bought this thing and was told its a Kaw Bayou 300. Maybe. I cant find any numbers on it.The one tag I did find its so faded as to be unreadable. Its a long shot but maybe someone can help ID it. Thanks in advance.
    • By Jeff Wharton
      I have a 2000 Arctic Cat 300 4 wheeler. I have been having some carburetor issues. So i bought a new carb. Now I'm having these issues. The unit will start and idle fine, when i go to accelerate it wants to cut off. So i checked to make sure it was getting gas and the fuel filter will be full of gas and then once the carb opens the filter drains down and will not refill quick enough to run. So i checked to make sure gas was flowing to the filter and it is flowing fine through the line. I remove the filter and run the gas line directly to the carb and the engine idle fine and then it will run good as i ride it for about 10 minutes then it will start with the same issues again i cannot accelerate enough to move the 4 wheeler. Every time i accelerate the unit will cut off. What is wrong with this thing. My 400 Arctic Cat is doing the same thing except it will backfire, I'm lost i have tried everything i know to do, what am i missing here. Thanks for your help
    • By Maurais
      I’m looking for new replacement shocks (front & rear.) on my 1997 Kawasaki Bayou 300 2x4. New OEM shocks are upwards of $400. I haven’t pulled the rims off to check the eyelet to eyelet length but I’m hoping an expert on this site does know( I called Kawasaki direct yesterday and they were of know help.) Any technical help would be appreciated. TY fellow members. Vic
