By Tinkeringreg
By kaidella
By qcm413
Hi,
thank in advance
By Mmessy83
I recently purchased a complete lt230s for$50. It was missing the kick starter gears which I got off eBay for $18. I’m trying to install the gears which after reading different threads about having it timed. I have it all timed but now it acts like engine is seized up but I know it’s not. What could be going on??? Any insight would greatly be appreciated.
By gt_jacket
Hi,
I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in. Neutral and Reverse lights work.
All gears shift fine with no issues, has anyone seen this before? Just wondering if it is a bad sensor or something needs adjusting.
