My atv starts with the first pull every time and idles good but when I give it some throttle, a raddling noise happens and the atv doesnt want to move. If I give it more throttle and the rpm are very high, the atv moves forward a little bit. Not sure what to do. Thanks for looking
could be a stretched drive belt (pray it is) or clutch is acting up ... there might be an adjuster to tighten the belt some ... rear of the motor you might see a nut with a slot inside, loosen the nut and you can adjust the slot left and right, just cant remember what way is more or less slack, youll find out easily enough ...
    • By BillR94
      Thank you for your time
      Bill
    • By Frank Angerano
    • By 97kingquad
    • By jannonballs
      2001 Yamaha Kodiak. Rebuilt and cleaned carb after sitting for 10 years. Got her runnin but now this clunking noise is happening and sometimes the engine stalls hard like the tranny or clutch abruptly stops the engine. This was not happening 10 years ago. Also the clunk will happen and the rpm's spike. See video. Any ideas before I tear into it?
      IMG_4791.mov
