I just bought my first quad... a 2008 Arctic Cat 700 efi.
Im having some issues with the ignition. If I turn it all the way to the right I loose power but back it off just a little and everything comes back and it will start
Does this sound familiar to anyone and do you think the ignition has to be changed or can it be repaired?
It does sound like the ignition switch is bad, its easy to replace and not expensive, but you have to get one from a Cat dealer, or order online at Country Cat
Mike
    • By realpilot
    • By OldATVowner
    • By tepin
    • By Shorty51
