Need a Good Problem Solver...Scrambler 90
raceware
I have a 2001 90 Scrambler, runs for about 50 feet & dies, after it stops electric starter barely spins it, kicks over fine but won't start again for about 5 minutes, then same thing. I just got thru installing new piston & jug, new carb with electric choke. Just needed to replace the choke it wasn't working right but I thought I was purchasing just the choke but was surprised when the new carb came in, FYI the new carb is longer in height than the original if anyone thinks that might be the issue. Tried moving the needle around , check gas petcock getting good gas.. I installed piston with arrow pointing down or front of motor.....I am baffled. Need a Good problem solver!!!!
My first step in problem solving is always the simple stuff first! I would try it again with the tools needed in my back pocket to pull the spark plug. Ride till it stops, yank the plug quickly and 1)-look for spark 2)-check to see if plug is wet or dry! That one test will lead you to the start of your correct action plan :).
    • By ResQ91
      Hi Guys!
      Or ??
      Dave
    • By kiriyaaoi
    • By DrtyGrlKristin
    • By Tuzz
