1986 Kawasaki Bayou 300 Synthetic Engine Oil
mmgood
  • 2 years later...
  • Admin changed the title to 1986 Kawasaki Bayou 300 Synthetic Engine Oil
I agree with carguydave, I'm using 20wx50w Valvoline full synthetic in my 2001 350 4x4 Yamaha Wolverine. I had no oil leaks the first 3 months I owned the ATV, (acquired the unit in 2016), before I changed to full synthetic, now my cylinder head on the left side has a film of oil from top to bottom. ATV runs great sounds great, and I'm still glad I have full synthetic in my machine. But depending on how old your machine is, it may develop some unsightly leaks.
    • By bob2007
    • By cavry
      Wiring shows White and Brown to solenoid blades. Then a black wire from starter circuit relay to solenoid. I am confused,  where is that black wire supposed to connect?
      Thanks for any help
      Cavry
    • By hardcastle
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
