I put new carb on a keihin got out in the woods thought we suck some dirt in it. Got it home still running but poor,quit running all together. Cleaned all out put back on. Float working right so is everything else seems to be anyhow not getting any fuel for it to fire you can choke do everything wont fire pull plug out its dry after you thought you flooded it.  You can pour a little gas down plug hole put plug back in and it fires. Any help or ideas would be great thanks.
So it sounds like if you give it fuel it fires, but its not getting fuel from the carb? Check the lines, is fuel getting into the carb? Something has to be up with the carb fuel delivery or you have some kind of choke issue.
* Moved to Honda Forum
Sottie, did you ever get this figured out?
Have you checked the fuel valve (petcock) ?
Make sure fuel is flowing from the tank.
If that does not work then I would think your fuel is not entering the the carb where the float needle is. I know it sound repetitive but you missed something. Go back blow everything out and double check.  Main and pilot jets all clear ?
    • By BillR94
      Thank you for your time
      Bill
    • By Asand211
    • By wjmedic
      right front hub again
    • By sunn
      Has anyone had experience with the installation of the Optional RH Side Panel Close Off Kit as shown as p/n 2207445 which is supposed to help control the heat on the right side on my legs?  Right now that panel is wide open with excess heat on my leg.
    • By TravisCr
