It idles just fine. I can ride it in the backyard and not have any issues. It only does it after being held open at high RPMs for more than 30 seconds. Then it seems like it is starting to bog down then dies. Then it starts right back up. 2002 linhai 260
Edited by County185
Sounds like  fuel  starvation. Something is restricting the fuel  entering the  carb. Some carbs  have a  screen  on the carb's fuel  inlet  and it  could be  plugged  or   a pinched or   otherwise restricted fuel  line  would be  my  guess.   For whatever  the  fuel  bowl  isn't  staying  full under  high demand.
Wide open   and not in gear does not require anywhere  near the fuel  flow   it  does under  load.   I  don't  of any  other reason  it would  die  out  the  way  you describe if it  is  not  fuel starvation.
Edited by davefrombc
Sticking  float ,  restricted  fuel  line  or plugged  vent  could all   cause those symptoms .  Start with  checking   for  a  restricted  fuel  line or plugged  vent  before tearing into the  carb.
    • By Jdeaton011989
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By jeffrocdx
    • By BillR94
      Thank you for your time
      Bill
    • By joezee13
