If I am not mistaken, the solenoid is mounted to the metal battery box. The box acts as a ground to the solenoid mounting bracket. Ensure the area the solenoid is mounted to is clean. Or run a short ground cable from the negative battery terminal to the solenoid bracket.
    • By realpilot
    • By logray
    • By OldATVowner
    • By cruteg8
