Bigger, Better Battery for '03 Kodiak 450
By p5200
The studs in the sprocket hub are stripped out. The hub is probably walloed out also. Probably will have to have a new sprocket hub. I doubt I have the ability nor the tools needed for this job. Thanks for all suggestions/opinions!
20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4
By Topendcol
Col
By jashadams
Snapchat-1142015191.mp4 -
By Gwbarm
By p5200
Hello folks, I have a Polaris 500 Scrambler. Not positive I need a new battery. The folks I got the ride from said they put a new battery on it right before selling it to me. It's been a couple cold months before I tried starting it. After jumping it now, I let it idle plus revved it quite a bit for about 20 minutes. Then I shut it off and tried to restart barely turns over and that's it? Am I not giving it enough charge time maybe need to actually ride it? The battery on it is a Continental CTX9-BX. I lf a new battery is needed would maybe Amazon have a decent one? Thanks!
