2017 Arctic Cat Alterra ATV Video
By tepin
By Shorty51
By quadcrazy
Best ATV for Older Riders
Polaris Sportsman 570 EPS
Best Reliable ATV for Seniors
Honda FourTrax Rancher EPS
Best Features
Best Premium Comfort ATV
Can-Am Outlander MAX
Standout Comfort Features
Best ATV for Easy Handling
Suzuki KingQuad 500AXi
Why Older Riders Like It
Yamaha Grizzly 700 EPS
Best Features
Arctic Cat Alterra 600 TRV
Key Advantages
Electric Power Steering (EPS)
Automatic Transmission
Lower Seat Height
Two-Up Models
Hand Warmers and Heated Grips
Adjustable Suspension
Buying Too Much Power
Ignoring EPS
Choosing Aggressive Tires
For most mature riders:
Final Thoughts
By spigmef
I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
