I have 01 quad I do not think the battery is charging right.I have the one ground that charges the battery off an my meter shows it's putting out14.17 or .19 when I give it gas it go up to 14.20 or .23 my head lights stay the same
Some makes of quads and other  vehicles will run  without  a  battery, but  not all . It  depends on the  make and  model. Like  cars  and motorcycles, many  newer  quads  are  going all electronic so  some of them  won't  run  without the  battery. I cannot  say whether  yours will  or  not .
    • By Adamb2025
    • By tds7
    • By shorty
      FYI: I used a volt meter to test the stator/rotor output. Pulled the plug on the rectifier/regulator to access the 3 wires coming from the stator. The other 2 wires are 12v pos and negative so easy to identify the 3 stator wires, which are yellow on my Kowhockey. You should see around 30v AC not DC coming from the engine stator. Test all three wires to EACH OTHER not ground. Remember the stator puts out AC like an alternator. The rectifier converts the AC into DC to charge the battery. On my case the rectifier/regulator was bad, obvious because the 3 stator wires showed 30v AC
