Hey chop, I asked a guy I know who has tons of atv parts he’s in PA but ships all over the place. He will take a look and let me know. If he does I will put you two in touch.
Why the need for a new one ? Beyond repair?
I’m assuming you checked eBay ?
You rebuilt it, ok got ya.  Well is it in decent shape ? Was the bike sitting,  and most importantly when you rebuilt the carb did you inspect the rubber diaphragm for any punctures or damage and is it seated properly ?  There is a tab that aligns the rubber on the carburetor. Also the airways in the carb are super important are they all clear ? It may need a good soaking.  Whenever I have a difficult carb I soak it in a gunk bin that you can buy at any auto parts store. It has a basket in the tank etc take a look I attached a pic. Maybe break it down really good again and soak the heck out of it and blow out all the passages again with a compressor. It’s worth a shot then a new carb $$. And the cleaning solution is reusable for future parts so it’s worth the investment. Also double check that rubber diaphragm and that the parts holding that main needle down in the diaphragm under the spring are in place there should be a washer then a clip that clips onto the main needle and then another washer that the spring sits on top holding the needle down. If this is not correct the needle jumps up allowing fuel to flow into the carburetor unregulated causing a rev up.
Hope this helps
It’s posable a new diaphragm may be needed but not if it’s in good shape. Double check that needle also make sure all the washers and clips are properly in place. That needle also should have some wiggle room when it’s Installed properly.  That carb works on a CV “constant volocity” so you have to make sure that the airways are clear. I’ve attached a link for your use and I encourage everyone that’s viewing this post to watch. It shows exactly how a CV carb works. Thus allowing you to look at what could be blocked or wrong. But just the general knowledge is great.
      Hello there
    • By Gtc4d
      Thanks.
      Todd
    • By digrig
      Hey everyone,
    • By shorty
      I removed a winch, mount brackets, relay box from my kawhockey ATV.. also a sturdy steel tube holder for a gas can.. CHEAP to someone who wants them
    • By Ant-Knee
      I recently picked up a '97 Prairie 400 4x4 that didn't run. I didn't get much information from the previous owner except that it was running a couple of weeks ago, then started losing power. After that, it just wouldn't do anything... no crank, no start. The electric start didn't do anything and the pull start seemed locked up. When I got it, it had no fluids whatsoever—no oil, no coolant, nothing. I figured the engine was seized. I took the pull start recoil off and tried turning it with a wrench but it didn't move. I took out the spark plug and put some lubricant in the spark plug hole. After a while, I was able to get it moving and it turns now but isn't super easy to turn. I put oil and coolant hoping it would fire up but still nothing. I took out the starter and tested it and it worked perfectly. I tested the starter solenoid and it clicked so I assumed it is working. The battery is good and holding a charge. I also put in a new spark plug as the old one was somewhat corroded but didn't look that bad. After I tested the starter, I put it back in and ran some power directly to the starter. It started cranking the first time I gave it power but didn't do anything after that one time.
      Any ideas of what I should do next would be greatly appreciated. Always wanted a quad so I really want to make this work but not sure if it is do=able.
