  • Admin changed the title to 2005 Honda 400ex Cylinder Head Fit 2002?
    • By colin james
      View File 2005 Polaris Phoenix 200 service manual
      This is the service manual  for the polaris phoenix 200 down load all chapters to have completed manual
      Submitter colin james Submitted 07/19/2018 Category Polaris ATV
    • By jmeier1981
      Ok so I bought the 05 brute force and after putting about 60miles on it I have some concerns.
      The engine seems to run REALLY HOT, like almost burnning my legs through my jeans hot but no warning light comes on and it doesnt seem to "act" hot is this normal, does it have any saftey feature to prevent over heating or heat damage?
      It also seems to have a slight miss, or hesitation? When you slightly crack the throttle open and hold it at a steady RPM to give it a slightly higher idle it will run smooth for a couple seconds then miss and sometimes backfires. It also seems to sometimes have a hesitation if you jump on the throttle, what could cause this?
      Also a couple times when shifting from reverse to high it sounded like it got hung up in between and there was a slight squeal as if maybe the belt was slipping and there was also a slight burning plastic of rubber smell. The belt IS new and it doesnt feel as if it is slipping when accelerating and the belt light hasnt come on.
      Anyone have any suggestions?
      It does seem to run really well and HARD accept for the slight hesitation or cough and the occasional backfire, I ran it up to 69MPH with both me and a buddy of mine on it, combined weight of almost 500lbs
    • By p5200
      I added more fresh gas it sat one day now, it's acting up again. Before cleaning out carburetor it wouldn't idle good and had gas leaks from carburetor. Now it idles pretty good but, if I increase throttle speed at a certain amount it starts missing bad. I'm going to try and post a short video. Just about ready to give up on this thing.😒  you can see reflection perking in video.
      20240217_114429.mp4
    • By exalrod
      Hi Everyone,
      I recently purchased a 2005 50cc Polaris Predator for my granddaughter.
      The wiring is a mess. most of it appears to be jumpered out (twisted together).
      I installed a new carburetor. The gas tank was cracked so I found another one on ebay and got that installed. There is no air filter box. I ordered another one but, it has not arrived yet.
      I did get it cranked with the kick start. But, it idles too fast and when you give it any throttle the motor dies off. The more throttle you give it the faster it dies off. It is very hard to start when it has not been running for a while. However, once it has warmed up, it starts on the first kick every time after that.
      I am looking for a little assistance in getting it running better and also a wiring diagram and service manual if possible.
      Thanks in advance....
    • By jatho
      Has anyone else had an issue on older king quads where the oil would leak from the top of the head (due to a failed gasket) and drip onto the hot exhaust? Mine got so hot one time it caught fire. Just wondering if this is a common issue, as I've seen the same thing happen on multiple bikes that were the same model.
