7 Compact Fishing Poles For Your ATV/UTV
By rjsummer
By middlebrookgt
By Ajmboy
I got a chance to go on a a fishing trip last weekend to Bimini. We flew down to Ft.lauderdale and took a prop plane to the island. Great time, about 40 of us went. Did some deep sea and bone fishing...Bimini is known for shark infested waters! Below are some pics...
By MikeyC85
Hi guys -
Working on my daughters Apache Tomahawk 50cc (GY6 engine I believe).
Wouldn’t start, noticed that the stator Magneto wasn’t turning with the engine.
Stripped it down fully expecting the woodruff key to be sheered/moved however this wasn’t the case.
It appears instead that the shaft itself isn’t engaging and/or is engaging intermittently as the engine turns over which is effecting spark timing.
Any ideas on what could be the problem - I’m at a loss!!
