2008 Polaris Outlaw 90 CC electrical system question
I recently bought a 2008 Polaris 90cc outlaw for my daughter it only needed a few things like a carburetor and a transmission shaft which I fixed with ease. The headlights on this vehicle are dim so I bought a aftermarket set of headlights also a  small winch does anyone know if the stator puts out enough voltage to run these extra accessories do they sell a stator that puts out higher amps? I would appreciate any help that you guys should give me
  • 5 months later...
Hi ; I been having a problem figuring out if theres a special way the transmission gears on my daughters 08 Polaris outlaw 90 {Automatic Trans} I put  it all together and the gears all mesh  correctly it goes into all gears F/N/R but when I try to put the shifter into the  shift gate it will only go into foward and neutral  because the travel is shorter  is a certain way the gears are set ?  I would apprieciate any help you guys can give to me, it rides  perfectly but w/o the shift gate attached im afraid I'll be rebuilding the thans sooner than I think
    • By Spritee1
      having an issue with the unit when running under a load up a hill or in high gear, seems like the belt is slipping, there is a clapping sound coming from the primary clutch like it releases and snaps back in. i don't think I should have a noise like that. this is a friends unit and he has already replaced the primary twice with the same result.
      not sure where to look next
    • By Johnfj44
      The stock driver seat cushion is separated at a seam. I took the seat apart and found that the material has torn and cannot be re-stiched. I'm trying to find a replacement seat. Any suggestions? Hoping for a used seat but couldn't find one on Ebay.
    • By HSTAR
    • By Slitzer
      Hi,
      Got a Big Boss produced 2016 YM 2017 that gives DTC 520 285 2 (random)
      What I understand is correlation code for brakesensors, very little information in workshop manual.
      Removed front plastic to discover that no connector was mounted on the brake pressure switch!?
      The only "brake" information seems to come from the micro switch at the brake lever.
      Does anyone know if Polaris does anything special on the 6x6 or had this issue?
    • By hardcastle
