I recently bought a 2008 Polaris 90cc outlaw for my daughter it only needed a few things like a carburetor and a transmission shaft which I fixed with ease. The headlights on this vehicle are dim so I bought a aftermarket set of headlights also a  small winch does anyone know if the stator puts out enough voltage to run these extra accessories do they sell a stator that puts out higher amps? I would appreciate any help that you guys should give me
  • 5 months later...
I don’t think your lights will have any issues weather led or incandescent, the winch in any bike however puts a huge draw on the battery and could also burn the stator out if pushed too hard ie runnning the winch too long especially with a load on it.
I would change the lights and hold off on the winch.
Hi ; I been having a problem figuring out if theres a special way the transmission gears on my daughters 08 Polaris outlaw 90 {Automatic Trans} I put  it all together and the gears all mesh  correctly it goes into all gears F/N/R but when I try to put the shifter into the  shift gate it will only go into foward and neutral  because the travel is shorter  is a certain way the gears are set ?  I would apprieciate any help you guys can give to me, it rides  perfectly but w/o the shift gate attached im afraid I'll be rebuilding the thans sooner than I think
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By Shorty51
    • By bradleyheathhays
      Unfortunately it looks like I have some people in my new neighborhood paying a little too much attention to my auto and for the first time I'm feeling a need to add some security system(s) to old yeller.  I think just a basic remote arm system would do, not interested at all in remote start or unlock.  I'm not familiar with modern alarm systems, but here's what I 'think' I need...
      - Door switches for all 5 doors (rear hatch).  Probably a PITA to install but that's only an initial idea.
      - 'Bump' alarm (not sure what it would be called) for if a window breaks or if something is jarred
      - Geo-location function like a low track or something similar
      Additionally I'd like to install possibly 2 start kill switches.  I'm not sure where inline these are normally installed but my impression is that directly in line with the key ignition switch would be common.  But then what if someone jumps the starter with a screwdriver...would this type of switch work in that instance?  So that leads me to the idea of a second ignition kill switch which would either be wired between the battery and starter motor, or between the starter motor and ground.
      And last...security lugs.
      So am I over thinking this here?  What's your recommendation for what I really need and maybe a good but economic alarm system that can get this done?
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
