Hey guys, new here so bear with me.. I hope I posted in the right area. I am curious if you guys run a semi or full synthetic oil. If a full syn blend, is it PAO? I'm trying to gauge my best option for the buck. Thanks
14 hours ago, GrizzlyRider said:
I've been running Valvoline 4-Stroke ATV conventional oil but on newer ATVs I would recommend Amsoil full synthetic.
I do the same and have been using the valvoline atv and motorcycle oil. BUt my quad is an older 2004 if I get a new one down the road, I'll start it off with synthetic.
Ive been told by my dealer if the machine is new, or had a top end done, to run regular oil in it for about 300 miles then change it over to synthetic. This allows the rings and such to seat properly. Running synthetic from the start is not a good idea.
Oil technology has come a long way. Its all preference at this point. The key is to change the fluids at the recommended intervals. Use any quality oil of the correct viscosity, change it regularly, and you will be fine.
I met some guys in the oil production business here locally and they let me visit the manufacturing plant. Learned a lot about oils, additives, semi and full synthetics. They are getting ready launch to the masses they told me and are working on a website.  They do real testing on dirt bikes and street bikes out there. Specializing in motorsport engine lubrication. He didnt give me the name but said when they launch he will email me. They use group3 oils to do the semi-blend and from what I read is a great base.? Just curious.
    • By BillR94
      Thank you for your time
      Bill
    • By kx9m
      Retired carpenter here looking for things to do... What else??  Work on old quads sounds good!!
      Here for manuals and advice..
    • By wjmedic
      right front hub again
    • By sunn
      Has anyone had experience with the installation of the Optional RH Side Panel Close Off Kit as shown as p/n 2207445 which is supposed to help control the heat on the right side on my legs?  Right now that panel is wide open with excess heat on my leg.
    • By exalrod
      Hello All !
      Could anyone help with this?
