2018 Argo Xplorer XR 500 EPS ATV Review
By en4cer
Problem number 1,
2000 Polaris Xplorer 400. No start, has spark. Has fuel ,found Low Compression less than 60 psi. What to do next?? Going crazy here.
Problem number 2.
1994 polaris Sportsman 400 starter won't engage. Button on left side with light switch seems to be almost stuck in, weak spring behind button?
Any help would be nice.
Thanks Chris in West Central Minnesota
By colin james
View File 2017-2019 sportsman 450/570 with eps factory service manual
This is the factory service manual for the 2017-2019 factory service manual for the sportsman 450/570 with electronic power steering
Submitter colin james Submitted 09/06/2018 Category Polaris ATV
By davefrombc
1996-2003 Polaris Sportsman 400, 500, and Xplorer 500 service manual
View File Polaris Sportsman 400, 500, and Xplorer 500 service manual
This detailed, comprehensive manual covers the Polaris Sportsman 400, 500, and Xplorer 500 4x4 from 1996-2003.
Submitter davefrombc Submitted 05/05/2026 Category Polaris ATV
By en4cer
I have a 2000 Polaris 400 xpress with a no start situation, I have spark and fuel. Wont start on starting fluid.
New fuel filter and spark plug. Did run prior on full choke. Then died and not start since. I feel dumb , any body have a clue???
By frugalsob
Hey all, been a while since my last post and can't find anything exactly like I'm experiencing.
I have a 1996 Polaris Xplorer 300 and have fuel consistently (based on my opinion) drip from the overflow tube attached to the bottom of the carb. When parked and the fuel petcock turned on, it does not leak. However, once its running, it drips almost 1 drop per second. But only at idle. Once rpm's increase it doesn't drip.
I've cleaned the carb, checked the float per service manual, and the rubber needle tip doesn't appear to be worn.
Is this dripping normal? I really dont feel it should be. Or, do I need to replace the needle despite how I feel it looks.
Any help would be appreciated!
Thanks!
