Recently picked up a Sportsman 90 with a bad transmission / gearbox. I had to rebuild the gearbox with all new bearings. It had been run underwater and the bearings were all rusted. Also tore into the secondary clutch and replaced the bearings in there. The primary (variator) seemed ok but I cleaned it and lubed the needle bearing with Super Lube. The issue i'm have is when riding it or revving it up, the front primary makes a load whine when it gains some speed. Is this normal? Other than the needle bearing in the primary, i dont see what else could be causing all the noise. thanks in advance for any help
  • Ajmboy changed the title to Polaris 90 sportsman 2014 Transmission Rebuild
Polaris does  not recommend any lube on the driven and secondary clutches or assemblies that I am aware of.  When we clean them we are told not to put anything on the bearings because it could shorten the life of the belt. If you give me the year of the unit is will post the factory service manual for you
Wow, thank you! It is a 2014. I lightly used Super Lube in there, partly because I use it on my Can Am Outlander primary and it will not sling out. It stays put quite well.
    • By logray
    • By Shorty51
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      AWD and differential repair
      Brake system service
      Popular related searches:
      Sportsman 570 wiring diagram
