Recently picked up a Sportsman 90 with a bad transmission / gearbox. I had to rebuild the gearbox with all new bearings. It had been run underwater and the bearings were all rusted. Also tore into the secondary clutch and replaced the bearings in there. The primary (variator) seemed ok but I cleaned it and lubed the needle bearing with Super Lube. The issue i'm have is when riding it or revving it up, the front primary makes a load whine when it gains some speed. Is this normal? Other than the needle bearing in the primary, i dont see what else could be causing all the noise. thanks in advance for any help
  • Ajmboy changed the title to Polaris 90 sportsman 2014 Transmission Rebuild
Polaris does  not recommend any lube on the driven and secondary clutches or assemblies that I am aware of.  When we clean them we are told not to put anything on the bearings because it could shorten the life of the belt. If you give me the year of the unit is will post the factory service manual for you
Wow, thank you! It is a 2014. I lightly used Super Lube in there, partly because I use it on my Can Am Outlander primary and it will not sling out. It stays put quite well.
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      AWD and differential repair
      Brake system service
      Popular related searches:
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
      View File 2020-2026 Polaris Sportsman XP 1000 S service manual
      Download the 2020-2026 Polaris Sportsman XP 1000 S service manual PDF for complete factory repair, maintenance, troubleshooting, and diagnostic procedures. This comprehensive Polaris Sportsman XP 1000 S repair manual covers all major systems including engine service, EFI fuel injection, clutch and transmission repair, AWD drivetrain systems, suspension, steering, brakes, electrical troubleshooting, wiring diagrams, torque specifications, and factory maintenance schedules.
      Designed for ATV owners, mechanics, mud riders, trail riders, and DIY enthusiasts, this factory-style service manual provides detailed step-by-step instructions and diagrams for maintaining, repairing, and rebuilding the Polaris Sportsman XP 1000 S high-performance utility sport ATV.
      Polaris Sportsman XP 1000 S engine repair
      AWD and differential service
      Suspension and steering repair
      Brake system maintenance
      Oil change procedures and maintenance schedules
      2020 Polaris Sportsman XP 1000 S service manual PDF
      Sportsman XP 1000 S wiring diagram
      Sportsman XP 1000 S maintenance schedule
      This Polaris factory repair manual is ideal for riders looking to maintain, troubleshoot, repair, or upgrade their Sportsman XP 1000 S for trail riding, mud riding, hunting, utility work, and extreme off-road performance.
