Similar Tagged Content
By hutchir3
Hello Folks....new to the forum. I have two Warriors (87 and 92), and an 89 Big Bear. Looking for some help with engine issues on the warrior, and my 89 Big bear backfired and died. Got spark, got gas, seems to have compression, (but haven't tested it yet...next). She rolls over good, maybe too good...seems soft. Have spark and enough compression to blow gas mist out the plug hole when cranking. Suggestions, Been running great since we got it.
By jolio
Just got a '98 Yamaha big bear 4x4 in working condition (so far). Looking forward for some good information on this site about how to keep it alive.
By Muskyjim
I recently purchased a 99 big bear 350 2x4 that was sitting for a while got it running and went to take it for a ride after about 10 minutes into the ride it stalled and wouldn't let me shift down into neutral tried rocking it back and forth but will not go into neutral...can anyone point me in the right direction on where to start?
By Christy Miller
Need a wire diagram for
99 big bear 350 4x4 can anyone help I have no spark my roommate drove it ended up losing the battery and it grounded out a.wire in the middle of harness was burned to BEAR any suggestions ty
Similar Topics
By xpnet
Hey guys I posted a while ago about my two quads but couldn't figure it out. So I gave it to my buddy he is checking them over, what do you guys think?
By Asen_77
Hi All,
My name is Asen and I am from Eastern Europe, Bulgaria. Riding a Yamaha Raptor 700R and this is my first Quad wanted for a vey long time :)
By AKMichael
Hello All,
I have a 1999 Yamaha Big Bear 350 4x4 trying to get fixed up so my grandson can go out in the woods with me.
We have owned it over 10 years. It got harder to start, until it finally would not. Replaced the carb. Right afterwards, it started and ran nicely, but after turning it off, would not restart. Tonight I used starting fluid and ran, then died. Adjusted the idle up a little, used more starting fluid and ran great. It idled about 15 minutes. Turned it off, and restarted. Ran it around the yard about 5 minutes. Turned it off, and would not restart.
Any ideas or suggestions would be greatly appreciated!
Thank you.
By AgmansGrizzly
Hello everyone,
Im new here, this is my first post and Im trying to figure out how evrything works on this site so I please let me know if Im doing anything wrong.
I have a couple Yamaha's but this post is in regards to my 02 Grizzly 660, I have an electrical draw somewhere that is taking my new battery down rather quickly. I have tried to locate any short by checking each circuit but was not able to locate it that way. Im installing a battery cut off switch which brings me to my first question, dont these switches usually go on the Negative terminal?
My next question is, can anyone tell me if this year and model has any history of electrical shorts that might help me locate the culprit? Any help would be greatly appreciated!
Finally, Im looking forward to being a member of this site and hopefully helping others as well as learning some things myself, so greetings to all!
Best wishes to everyone!
By mike91
I’m just wondering what year bike i got? it seems the vin has been rubbed off i got it from a auction here in Australia engine starts but seems has a dirty carb wont idle well
and also has a problem I put it in gear and makes a grinding noise but does not move it the neutral light goes out but then when I change gear it grinds more in the higher gears as well I’m guessing the differential is stuffed so wanting to buy new part for it will start the pull down next week
this is the first bike I have worked on used to dealing with cars
