getting my first quad, need help
hobaoe
hi, so i decided that i want a quad.  and i want a sport quad.
so, i want to be able to ride it on the road and offroad and such, nothing crazy. i dont know were to start, like how many cc? automatic, 2 or 4 stroke, 2wd-4wd, brand, and so on.
i dont want to have a beginner model and work my way up, i want the baddest and best now:D
ive been thinking of dirtbike first, but when my coworker expalined about how many times you must change oil i thought he was kidding but no. so i hope its not the same on the quad motors.
thanks for any input...
okay, ive just had a ride on it, and even tough ive never ridden one before, this cant be this unstable. ive checked up on the owners history and it had been sold fairly quickly from person to person, so i think that is the reason.
the problem is that it shoots side to side and wander very much from side to side. i had it up to 60kmh and that was very dangerous, its like it hops a few cm to one side even tough i am keeping it straight.
im gonna google some and fix this problem. if you guys have any suggestions i would appriciate it.
Get the toe fixed so the wheels are pointing straight ahead, and make sure the air pressure is the same from side to side. If riding on pavement at high speed I always feel a little nervous since those high grip off tires aren’t made for that
Rob
Edited by rdlsz24
i just changed over to the stock off road tyres, and i must say that it rides so much better. even on pavement. the ones that was on it when i bought it was slick pavement tires, but every bump and tracks in the road made it "all over the place"
also i had much better controll over the quad with the dirt tires. so im very happy now
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By Spritee1
      not sure where to look next
    • By NZrider
    • By jatho
    • By mkibbe
