By joshua91673
first post
josh ohio
By Wonderwoman
I am hoping that someone here can give me some more ideas. Our poor old red 300 won't start. We rode it, running fine, shut it off and now it won't start. Have gas to the carb and spark at the plug. Valves are adjusted. Still won't start. Tried a little starting fluid in the air chamber and still won't start. This poor old machine has 7000 miles on it. That has to be an Arctic Cat record! And I have never touched the engine besides setting the valves. Unfortunatly it looks like it only has 60 psi of compression. Don't understand how it could be running fine and then nothing. Someone give me a clue as to what I am missing or what to check. I was going to rebuild the top end this next spring but didn't want to do that this winter in a non-heated garage. Any help?
By Sblt80
Lt 80 had new top end rebuild and will not start now,
I have a spark and compression
even tried putting fuel down the barrel but still nothing.
hasn’t even tried to start or back fire since rebuild
can anyone help please
By bobg
Had the starter solenoid hang 87 Big Bear while I was riding it. Wrecked the battery. Put a new battery and solenoid in. Wont start with the starter, but will start with the rope and runs great. The fuse is good, but I don’t have any continuity through the circuit breaker. I’m assuming there should be. Can’t find one online, can I replace it with a fuse? Posted a picture of the circuit breaker.
Bob
By lporter
Put in new carburetor, battery is good, 30a fuse in starter relay good whe I push start button nothing happens except buzzing sound from batt. All lights come on. Won't start with pull cord either.
