97 Polaris sportsman 500 runs about 10 sec then dies
Danny Gardner
Hello, Everyone first time here, I appreciate this opportunity, I have a 97 polaris sportsman 500 that I just acquired, been sitting awhile ,would not turn over with a new battery, replaced the starter, got it to turn over, but no fire, replaced the coil, cdi box, new spark plug, spark plug wire and boot, still no fire, So I changed out the stator, boom I have Fire, Carburetor was in bad shape ,so I installed a new carburetor, a new fuel pump and filter and all new hoses, and before I tried to start it I cleaned the fuel tank, well here we go, It started right up idled like a brand new one, Idled for about 10 seconds and died, fired right back up idled great and revved up great, but in 10 seconds it died, fired right back up, this time I held the throttle about half throttle, and it kept running, but when I let off it died, so I then adjusted the throttle cable from all the way tight to all the way loose, and vise versa, still the same thing, Please somebody help, cause I'm bout to give it the HAMMER TEST.
Hahahaha the hammer test.  That’s a new one. So my guess is that the fuel in the bowl of the carburetor is being used up and then being starved for fuel hence the bike shutting down. So I would think the fuel delivery to the carburetor is restricted somehow.   I would make sure the fuel delivery from the tank/gas valve, through the pump is working correctly.  Take the fuel line off of the carb and aim it into a can of some sort, pull the spark plug wire ao the bike won’t start and crank the bike and see what kind of flow you have coming from fuel line. If it’s flowing good then that’s great. If not start working your way back.
 A lot of times when you do all the cleaning of the carb and tank etc sometimes a piece of leftover junk in the tank can get into a jet, float pin etc.  it sucks but can happen.
You can also get a small fuel tank and connect it to the carburetor and let gravity feed the carb, start the bike up and see if it runs steady.
Is the new carburetor an oem or aftermarket? We seem to go through this a lot with oem versus cheap replicas.  They don’t work very well.   The oem carb as long as it’s only a dirty/clogged carb it’s nothing a good soaking and cleaning could not fix. Must be taken apart and properly cleaned.
Is this something you can do? It’s not hard.
11 hours ago, Brian Haley said:
Will it run continuously with the choke closed or is it the same thing? Also when it runs for those 10 seconds what is the idle speed and does it die out or shut off abruptly?
Its the same thing with the choke either way, the Idle speed is normal it idles great, and revs perfect, but in 10 sec. it dies like you turn the key off
6 minutes ago, wanrep said:
2 things come to mind. 1) check the ETC in the throttle. Make sure there is a gap between the contacts at idle or you can just unplug the wires coming from it.
2) the idle mixture screw or the idle speed screw need adjusting.
I've checked the ETC, and its good, I also unplugged it and tried it, the idle speed screw I have adjusted, but I haven't checked the idle mixture screw, should that be at 2 1/2 out?
2 1/2 out is a good starting point. It should idle at that setting.
I still think it's running out of fuel. The fuel pump runs off of vacuum. If the baffle or spring in the pump is too stiff, it would give the symptoms you describe. I would hook up a gravity feed external fuel source and see if it will stay idling. The other thing that is a possibility is that the engine isn't producing enough vacuum. Try the external tank first, then we can go from there.
On 11/24/2018 at 12:13 AM, carguydave said:
Oh, one other thing, check that there isn't a small vacuum leak in the hose to the fuel pump and that the lines are routed correctly.
I found the Problem I did all the things you said, but still same results, so for some reason, I decided to take the new cdi off and put the old one back on,and boom that was my problem it runs like a champ now, Thanks guys for all your help I appreciate it.
got a friend with an 02 sportsman that has this same issue with the ETC and he has never really figured it out...(he doesnt really care about the bike so he just keeps his thumb on the throttle when he wants it running- a pain for me to run tho since im not used to never coming to a complete idle..lol  could you expound on this more maybe?  what is the ETC? and what does it do?
oh never mind thats not the problem.
@wanrep so that little son of a bi*** etc had me going nuts on one of my older Polaris bike projects.  I could not figure it out for the life of me. It was brought to my attention by a member @davefrombc on this site that the etc could be giving me trouble.  Backfiring spitting etc. anyway I removed the part all together and that bike ran like a champ.  I would have been looking for quite some time before I figured that out.  @davefrombc 👍
    • By Slitzer
      Hi,
      Got a Big Boss produced 2016 YM 2017 that gives DTC 520 285 2 (random)
      What I understand is correlation code for brakesensors, very little information in workshop manual.
      Removed front plastic to discover that no connector was mounted on the brake pressure switch!?
      The only "brake" information seems to come from the micro switch at the brake lever.
      Does anyone know if Polaris does anything special on the 6x6 or had this issue?
    • By HoldenBoy
      Hi all,
    • By Johnfj44
      The stock driver seat cushion is separated at a seam. I took the seat apart and found that the material has torn and cannot be re-stiched. I'm trying to find a replacement seat. Any suggestions? Hoping for a used seat but couldn't find one on Ebay.
    • By bighoss
      i got my son new outlaw 50 a few weeks ago and we went rideing yesterday and while we were riding it died and it took me like 10 min to get started back and it died agen when we got close to truck so i pulled it back took the plug out it looked like it was drop in a bucket of gas took the air filter out and the ait box was full of gas also got home it started rite up today i started it it starter up but was blowing what look like water out of the exholst let it idel for a lil bit did not die but as soon as hit the gas and let off it will die what does that sound like i thnk i going to take it back to dealer and tell them to fix it as it is under warrenty but would like to know what it could be first
    • By McG75
      Sorry I suck at these forums so if you see this submitted under update status, my bad. Anyhow this is a new shock for a 96 Yamaha Kodiak 400 4x4 it fits my 96 Yamaha Timberwolf 250 4x4 perfectly. Little narrower are the bottom than the original but everything else is perfect. I extended it to almost a half in from full extension because I’m pushing 350 pounds.  It rides and hold me well. So if any of y'allRace driven shock. have been looking for one and didn’t want to do the research here it is.
