I've got a suzuki 250 4×4. I've gone there it almost entirely and it idles fine but when I give it gas it bogs down never winding tight. All it doesn't have is a breather box would a breather box cause this problem
There have been  some  members found that without the breather box and air filter their machine does go lean  and bog as you say yours does.. You could try restricting the  air a bit either with  the  choke or just  by partially blocking the intake with your hand and see it it will rev up  ok .
    • By docdoug72
    • By RadRob
    • By Mhatayas
    • By beast6228
      However, last night I was looking at the service manual and noticed that it mentioned that this atv has a crankcase breather tube as well. Mine does not have one, so I looked at Partzilla and looked at the parts diagram and sure enough, it's definitely supposed to have one. The problem however is, the service manual does not show how it hooks up and the parts diagram only shows the exploded view of the assembly. I just find that kind of strange, nowhere in the manual does it show how it connects. Does it have it connector, attach to a nipple? It just doesn't say and it bothers me that there is a hole there without anything attached to it.  If anyone has a Bayou 300 or Lakota 300 with an intact breather vent system and could possibly take some clear photos of it or know how it connects I would be very grateful. I have searched high and low and cannot find any information on it.
