2009 Arctic Cat 90 not going into gear
By jeffrocdx
By quadnut20
By middlebrookgt
By C2INS
Does anyone know if they're interchangeable? I have a 2002 TRX20TE and 2007 TRX250TE, so getting to a set of common engine parts would be ideal.
By joezee13
