By That229Yamaha
Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
By Whiterabbit
Hey all, from SW Virginia here. I just picked up a '01 Bombardier Quest 650 on the cheap (seller couldn't get it to start). After correctly plumbing the fuel pump (new pump the prior owner installed but had the hoses going backwards lol) and cleaning the carb and fuel tank, repaired all the batt - and batt+ connections she lives!! I had swore to the wife unit I wouldn't be dragging another "project" home but I couldn't pass it up, it had new tires, new starter, new fuel pump and low hrs. All's good after she took it for a ride! 😆 It rides like a tank, very stable and tons of power.
By JoeB
Considering pulling the pin on an ARGO xplorer 570 xrt 2 up unit. Has anyone had any experience with these. They offer a pretty good sounding warranty but I don't know anyone who's got one to know if they're good about following through on their warranty promises
By gatorschevy
I also have a magnum 4x4 that I am working on it is getting a new piston, In the tear down I pulled off the flywheel
and found that all the magnets are not attached? why does this happen? there all in good shape so is it possible
to reattach them to the flywheel? I can buy a different flywheel, but it looks like around $300 or more and one of them on Ebay
looks like the spacing is off a little so it may have the same issue.
the stator looks good also
