If you can't find marks,  pull the intake valve cover,  rotate engine counter clock wise until the valve moves then continue to rotate using something soft like a straw in the spark plug hole to tell you when the piston comes to tdc
22 hours ago, Kartmanz W said:
Does it have a rubber plug in the crankcase to align a timing mark?
No,it does not,but I did just like Jeremy Morris says on his comment, Not with the straw but something similar,thanks for your help,very much appreciated.
  • Admin changed the title to Timing marks 52FMH Coolster/Kandi 110cc
    • By toe420
    • By DexKing
      Good day everyone!
      I am pretty new to ATV/UTV/Small engine repairs and would like input on your absolute must-have specialty tools for maintenance and repairs. Aside from the obvious wrenches and sockets, what are some more specialty type tools you use for troubleshooting? I don't plan to open a repair shop or anything, I just do this as a hobby. Looking forward to your responses!
    • By digrig
      Hey everyone,
