Do'in Some Track'in - 12 Mar 2019
By mikeexplorer
By DaveswMN
Drove about 100 yards, ran about half throttle wouldn't idle. Put on somenew parts, jug/piston and rings, carb and valve seals.
Thanks for any thoughts.
By DayBreakJim
20230725_171507.mp4
By Ulfthednar
The Dog loves the runs.
https://youtu.be/tKjBFuHCkM0
