  • Admin changed the title to 1999 Kawasaki Prairie 400 Auto 2X4 Know Problems?
Go through the gears and make sure they all work.  Double check the fluids, look for welds on the frame for a wreck/repair. Make sure the underside of the plastics match color so you know none were replaced.
There is a post here about buying a used bike. I posted the topic a little while back.  You will find a considerable amount of members input there and have a good idea what to look out for when buying.
Good luck.
    • By mehim
    • By logray
      Hi all,
    • By ButchM
