Warn Industries offers the most trusted, recognized, and innovative winches on the market. Asked for by name and proven in the harshest environments worldwide, WARN winches are the only name to trust when it’s all on the line.
From April 1 through May 31, 2019, Warn Industries is offering to put cash in your hands and WARN winches on vehicles.
Whether you're looking for a Standard Duty VR winch, a Premium ZEON, the Ultimate Performance of the ZEON Platinum, or a Heavyweight series winch, you can get up to $100 cash back this spring. With a variety of features, capacities from 8,000 lbs. to 16,500 lbs., and legendary WARN durability, we've got a winch for just about every rig out there.
If you're after a winch for your ATV or Side x Side, we've got a rebate for powesports vehicles, too. Get $40 cash back on our new line of state-of-the-art AXON winches and our high-performance standard-duty VRX winches. Both feature IP68 waterproofing, an array of features, and capacities ranging from 2,500 lbs. to 5,500 lbs..
Be sure you're ready to GO PREPARED this spring and equip your vehicle with a WARN winch. This is a limited-time offer, so don't delay—check out the details on warn.com and check out some of the Warn ATV winch lineup on Amazon.com
Warn ATV Winch
NAME PART NUMBER CASH BACK
VR8 WINCH 96800 $50.00
VR8-S WINCH 96805 $50.00
VR10 WINCH 96810 $50.00
VR10-S WINCH 96815 $50.00
VR12 WINCH 96820 $50.00
VR12-S WINCH 97035 $50.00
ZEON 8 WINCH 88980 $75.00
ZEON 8-S WINCH 89305 $75.00
ZEON 10 WINCH 88990 $75.00
ZEON 10-S WINCH 89611 $75.00
ZEON 12 WINCH 89120 $75.00
ZEON 12-S WINCH 95950 $75.00
ZEON PLATINUM 10 WINCH 92810 $100.00
ZEON PLATINUM 10-S WINCH 92815 $100.00
ZEON PLATINUM 12 WINCH 92820 $100.00
ZEON PLATINUM 12-S WINCH 95960 $100.00
16.5TI WINCH 68801 $100.00
16.5TI-S WINCH 97740 $100.00
M15 WINCH 47801 $100.00
M15-S WINCH 97730 $100.00
M12 WINCH 17801 $100.00
M12-S WINCH 97720 $100.00
AXON 35 WINCH 101135 $40.00
AXON 35-S WINCH 101130 $40.00
AXON 45 WINCH 101145 $40.00
AXON 45-S WINCH 101140 $40.00
AXON 45RC WINCH 101240 $40.00
AXON 55 WINCH 101155 $40.00
AXON 55-S WINCH 101150 $40.00
VRX 25 WINCH 101025 $40.00
VRX 25-S WINCH 101020 $40.00
VRX 35 WINCH 101035 $40.00
VRX 35-S WINCH 101030 $40.00
VRX 45 WINCH 101045 $40.00
VRX 45-S WINCH 101040 $40.00
POWERSPORT WINCHES REBATE FORMS
CONSUMER REDEMPTION FORM
    • By quadnut20
      Here's a couple of pics of our ride !!
      April 15_2026-04-15.mp4
    • By DonB
      Had fire start in muffler due to failing fuel pump &/or fuel pressure regulator.  Must I spend the $750+ for a new assembly from Arctic Cat?!?  Here's what I've tried so far.
      Replaced fuel pump & regulator - both from Quantum. PSI is 60 rather than the 42 the dealer advises it should be, so problem persists.  I've now twice replaced the Quantum regulator & discussed w/ Quantum. They advise that they don't have an alternative regulator that would bring PSI down to 42. I've tried several in-line, adjustable pressure regulators but they either didn't work or I couldn't get a constant pressure from them. FYI, I've only tried the adjustable regulators for Fuel Injected engines however, it seems that they require vacuum to function properly.  When I can temporarily get the PSI right, everything works great.  Anyone else ever dealt with this problem, and, if so how did you fix it?  Perhaps I should adapt the fuel system to include a gas tank return line?
      Any insights are greatly appreciated, Don
    • By MarkinAR
      For you guys that have full time 4wd like a Honda 300, 350 Rancher, etc that is all time 4wd Warn used to make a 424 that was a manual disconnect that replaced the front drive shaft. Warn sold the patent to Wide Open and they made a cheaper made unit. They were about 300 but are out of production. The few left are bringing 800 now. So here's my question; Maybe I'm reaching here, but since there is basically no such thing as a 424 anymore, have any of you fine folks thought through whether you can make a transfer case that will disconnect? If you could move either gear forward a half inch it would be disconnected. Thoughts?
    • By cavry
      Has anyone changed the steel cable on a 1500 lb. winch to dyneema?  Was this a positive move?  I live in the mountains of Ga. near the Ga/NC line.  There is lots of rocky ground, rough creeks and gullies, and too much red clay. I've used the steel multiple times (a couple of those I needed my doubling block) with no negative outcomes.  Anyway, are there benefits to Dyneema? What is the working life? Does the cost justify the effort to change?,
    • By David Cameron
      The small waterline insert for the hose that goes from the water pump cover to the thermostat housing has corroded off. I only need the insert on top and behind the thermostat housing that the hose goes over and can't find just the insert. It looks like it may be pressed in. I've have been told the entire motor housing needs to be replaced. The pic with the red line indicates where the hose and insert would be and the insert looks like the pic of the water pump  Any ideas would be really appreciated.
