picking up atv tomorrow, guys says motor is locked up. he thinks, anyway has been sitting for more than three years. Please understand i have not touched it yet but if his description is accurate im looking for suggestions on freeing it up before  having to tear it down. I'm hoping to get some great info from the pros on Quadcrazy.
Okay. With locked up motors can mean a few things. Stuck piston from no oil. Bad crank. Blown apart trans and so on. Your best bet is to look at the oil that's in it. Look for metal shavings in the oil. That's as simple as taking the drain plug out and fill the bottom of a regular plastic cup and inspect. If that checks out then pour a little bit of oil in the sp hole. Let is soak and move it till it frees up. This might take some time. Third is the dogbone. That might be seized. And 4th. Bad bearings on the crank.
I had a badly seized engine a while ago, leaving diesel to soak in the bores is probably the best advice and then hopefully it should be able to release it, providing there isn't too much water ingress!
Good luck!
    • By docdoug72
