    • By jeffrocdx
    • By Rockbottom
      any ideas how to correct
      thanks ahead
    • By middlebrookgt
    • By sunn
      Have a high heat issue on the right side panel on my 2021 cforce 400, as complained about by the wife.
      My heat gun shows after 15 minute ride in ambient 91 deg temps;  690 degrees on front end of muffler close to entry pipe and 375 on exit side of muffler.  The right side plastic (where wife's leg would touch) was showing 175 degrees.  This is rediculous!.
      As I understand the muffler has a built in catalytic converter which obviously kicks off high heat particularly at front end of muffler, but the heat is atrocious.
      What is everyone doing about this problem?  Is there a replacement muffler to eliminate this issue?
    • By sunn
      Has anyone had experience with the installation of the Optional RH Side Panel Close Off Kit as shown as p/n 2207445 which is supposed to help control the heat on the right side on my legs?  Right now that panel is wide open with excess heat on my leg.
